Hi guys, appreciate bit of advice please..
One old rad , of three, old ones, has given me problems for couple of years.
Warm top, cool bottom.
13 Rads on system
Tried everything except removing and doing it with garden hose.
History.
Last year drained it , removing both pipes at the bottom from rad, water clear as a bell ?could have drunk it, it was that clear, no sign of sludge, or colour
Left it in situ thinking pipes were maybe blocked or airlock.
Replaced Trv(, the inlet pipe to the has always been hot, to touch, but ràd at point of entry, col !) Hence replaced T R V think it,s faulty, no change.
Water coming out ok, kept topping up system high, 2 bars,, and turning T R V valve open and shut, umpteen times till water was clean, but of muck , but nowt to bother about !
New kitchen rads fitted, system drained several times to fit new rads, system clean.?
Drained again, boiler problem, water clear!
Still rad not getting hot.
This
April had new boiler and system flush by firm, assumed problem rad would be clear, surely. been properly power flushed with chemicals, and magnatec flush.
NO!!!!!
Since using CH from october,same old, pulling my hair out.
Belting it with rubber hammer, etc,
Turned all rads off except problem one, still same, turned T RV off, bled rad into bucket, from bleed valve, vice versa other valve.
Again today, thinking airlock again.!!!
Re_ filling from either side ok, so inlet, outlet pipes working ????
I have got it hotter several times ,not as hot as other old ones, or new. but just reverts to same old after a few days.
Hence, taking it off and trying to flush by hand, tomorrow,till spring, and change all three old rads, with new ones.
Any advice would be greatly appreciated. Still not convinced rad iss sludged
up, but nowt left I can think of trying till spring ?
Cannot think of what else could be problem !
The rad is ,2.5 metres long, to change it, no longer made,so means buying , 2x2metre ones and re decorating, got two of them.
13 Rads on system
History.
This
NO!!!!!
