Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
hi very difficult to get cement to site, thinking mixing on site, but concerned using 85 litre hire mixer will take for ever for 4-4.5 m3,also i take it mix fairly runny to help level? cheers
most builders would use a concrete pump for hard to reach sites these days -some companies have a concrete mixer with pump attached -yes its expensive but the extra say £300 or so is worth it
a pump can usually do a run upto about 100 metres
from memory a 2 guy team can mix a cubic metre of concrete by hand in around an hour, maybe 40 minutes if they push it. no builder would consider doing a 4.5 metre cube by hand
cheers no just low walls in garden but very long some 40 metres in total, ive got a minimix company coming, but first comment was wanted to charge 170 a metre, but mine are mostly only 300 by 300 footings so as say about 4-4.5 cubic metres, also needs to do steps up small steep bank approx 900mm any advice?
I suspect you did. They won't care how you want to spread it, charges are always volumetric, probably with a minimum charge (3 cubic metres seems common)
