Please will some one help me.
I need to know if it is possible to modify a forctic tank so that i can create more head of pressure for the hot supply. Im thinking of simply capping off the cold feed to the cistern then cutting the cold feed from the cistern to the cylinder and then fit a compression coupler. Then fit a 50 gallon roof tank to feed the hot water cylinder and conect to the compression coupler. I should then be able to run a 1.5 bar shower pump right?
Also where does the open vent terminate on a forctic because i will need to incorporate this in the modification.
