ford escort ...water in the pasenger floor space
2 Nov 2005
Ok guys where can this water be coming from ... I have a large puddle of it in he passenger floor space. must be rain water but where is it coming in
Could be from engine compartment or wheel arch I suppose, you will need to look for rust.
First check your heater. Second check the drain pipes on the bulk head.
Check under the battery they are known for leaking under the battery tray
i had same problem on an orion, water was getting in under battery as other reply suggested, not much of a hole more -rust and pinholes/ cleaned it up ,bit of filler and a good thick coating of underseal painted on / no more problems. r.r.
