FORGE STEEL SCREWDRIVERS ARE PANTS
MDW
10 Mar 2011
Bedfordshire
Bought 6 piece set one month ago,pozi head rounded,3flat heads snapped.Even the little one with a clip on the side has fallen to bits without even using it. NOT a bargain. FORGESTEAL more like FORGE TIN. That said, the crimping tool is good. Cant work out how to set it up to the larger sizes though??
I've had fung-yip drivers for 10p which have at least lasted a while under normal use, so I don't know how FS drivers can be that bad.
Did you follow the instructions?
