I am looking to install a 6m x 5m garden building at the bottom of my garden. It is of a SIPs construction with insulation etc. For foundations there is already a concrete base which is approx. 300mm deep approx. 9m x 7m so plenty of room for the building to be located on.
The issue is that these buildings usually sit on concrete piles with a timber sub base clear of the ground. In this case I need to ensure the timber sub base is clear of the concrete base. My idea would be to run a course of engineering bricks around the perimeter for the timber sole plates to be fixed to. The other alternative I thought of was to use concrete lintels.
I would be grateful if anyone is able offer some advice/experience of this situation. Additional insulation could also be laid in the void formed by this perimeter.
Thank you
Thank you
