Foundations - Found Slate
19 May 2006
Just started digging my foundations and I'm down to solid slate at around 600mm below ground level. At the low point in the slate there is a small trickle of water running across. I was going to trench fill, is this still possible, or is it going to get expensive?
Can this be resolved with a Building Inspector who know's what he'd doing, or do I need a design from a Structural Engineer?
Is there a possibility I can pour on to the slate, linteling over the low spot to allow the water a passage?
Happy to pay for the SE, just trying to get an idea of how difficult this is going to be. Thanks.
Sounds a bit like shillet, quite common in Devon/Cornwall, not sure about elsewhere, if it is then it'll be solid as and you'll be able to bear directly on it, get your inspector out to have a look if you can, why do you need to create a passage for water?
Thanks for the reply FMT,
I'm in Wales so I was expecting slate, but it could be shillet. I thought I'd need to create a passge for the water so that it doesn't affect the strength of the concrete, or caused problems when it found a new natural route. I'll probably keep digging and get the Inspector to have a look.
If it was me I would clear the bit by the brick work and get sight of the existing foundation. If the rock band hits a certain mechanical strength in your area, your BCO will know you don't actually need to pour any concrete , you can just clean off the surface and build off the rock..
