Hello,
I have recently moved into a house that has a Danfuss FP715, a potterton boiler and sealed radiators.
If I press the on for 1 hour switch or press the auto button then the boiler heats up but when I set the timer for the CH to come on, the red light shows but the boiler doesn't fire up.
Also a couple of radiators heat up fully, a couple only heat up around the edges and 2 don't heat up at all. They are sealed units with no key area so I'm not sure if they need bleeding and if so how would I do it?
Thank you in advance if you can help me
