Freeezing pipes
11 Mar 2012
Cambridgeshire
Following on from my "shower too powerful" question, and thanks for your help with that one, I'm on to the next one. Buddy needs to install a stop cock in a 22 mm mains pressure pipe near one of the apartments so they can isolate that room since it's rarely used.
But they can't turn off the water supply to the whole building and "someone" told him, "all he needs to do is freeze the pipe so there's no water flow, cut it and fit the new stopcock and then let it thaw out". Is that so? And is this something we really can reliably do easily from some kit we can hire or what?
TIA
Yes you can hire a electric plug into mains , freezer kit . As to easy , that depends on type of pipe , situation of pipe + how much damage it`ll do if you don`t get it right - in a DIY situation . As a pro plumber I would go for shutting the whole block , but then I`m cautious :wink:
If the main feeds other flats, it could make it more difficult to freeze, if someone in another flat opens a tap you will lose your plug before it has set.
Although less likely with a machine, some of those are carp and I wouldn't risk it.
The cans of pipe freeze are a definite no in this situation.
As above, inform the tenants and turn off the block, it will only be for a short period
