Hi all, I've got loads of useful info from this forum but this is my first post.
I'm looking for some advice regarding drainage around my house. It's a 1911 build, single-skinned semi detached and we've had damp issues since we bought it back in November 2014.
Initially we were told that a DPC would cure all our woes but after buying I found out about the single skinned wall and that a DPC would be utterly useless for us. After months of research and heartache we finally took the plunge and had the house re-rendered in lime. This has cured 90% of the damp issues (water ingress, saturated walls, mould, condensation) but we still have issues with damp getting to the foundations and causing issues with the space underneath the wooden floor in our front room. The lime render also makes it easy to see that all the external walls seem to be sucking up water from the ground. I should mention that the ground level outside is pretty much level with the internal floors, the surface is tarmac.
I believe a french drain around the perimeter of the house would address these issues by stopping the ground water getting to the base of the wall. I am after some advice as to how to ensure it is done correctly. I know we need to make sure the foundations are not too shallow or we won't be able to position the drain close to the wall but i don't know how to find this out.
Does anyone have any handy tips/advice please?
Many thanks.
Many thanks.
