A French drain or land drain can be used to reduce the pressure of ground water acting against the base of a wall but this only applies where you have high ground sloping down to the wall.
A French drain will not dry the ground magically but merely interrupt the passage of groundwater and therefore remove any pressure.
A french drain may help keep the subfloor drier if you have a large pressure of groundwater as mentioned but if you live on flat ground it will mist likely do nothing.
The render wicking moisture is a completely separate issue and French drains will not help.
