Hi
1. First off this looks like a case of getting in a SE? Dont do anymore digging (anywhere) let a SE have a view.
Hi, no need for a SE, I've had a few round over the past 18months, why do you think there's a need?
2. Your 2" x 4" joists appear to sit on plates over timber beams.
The two joists in the c/breast recess appear to have decay and have been packed up.
Hi, there's no decay, they're on the original sole plate on top of the dwarf wall?
3. You have some neat looking, well applied Tyrolean render - is the inside of that wall dry?
That crappy render is the largest part of the problem, its the other side of this wall. It was 1" into the outside ground level, I've removed it all from the
original stone to let it dry out and do its job.
4. Could you get the neighbour to agree to lowering the high ground level? Quite how low is difficult to know, care must be taken not to de-stabilise the "foundations". Dont do any digging inside the wall.
I'm going to ask if I can, we get on well, even if I can it'll only be by about 8", which will help. I'm going to put 40mm stone next to the wall so no moisture is held against it if I can't lower it.
5. I dont know how far you are going but the hearth area might be a source of dampness and fungal decay - its only a possibility.
Its dry as a bone, what you can't see is that that wall(gable end) floor level is about 6 ft over outside ground level
6. The built-up chimney breast recess might be allowing rising and penetrating damp.
Yet again, all dry as a bone
7. What kind of air bricks (if any) do you have?
None yet, they're going as this room goes back together.
8. Do you have underfloor ventilation?
As above, I'm going to put vents in the gable end and the south facing wall and allow cross ventilation by putting air bricks in the dwarf walls
9. The best practice for plastering in your situation is to knock off all earlier plasters, and render in sand & lime.
I've removed all gypsum plaster and lime plaster thats had paper/none breathing paint. That wall has lovely lime plaster with a limewash finish.
10. FWIW:
Remove all rubble from site as soon as its produced.
Remove all proud nails from joists - immediately.
Clear the work area of everything thats not in immediate use.
Dont lean props - lay them down.
Mark all your floor boards as you lift them.[/QUOTE]
All boards have been marked
All rubble is removed the day it gets there
everything in the pic has been used today
I'm not going to remove nails until I can see the whole joist is still in good condition incase its a waste of time.
Thanks for you comments, good to know i'm going at it the right way
