Fresh plaster and Acrylic Eggshell
11 Mar 2014
London
Hi
Great forum BTW.
I'm about to paint my recently plastered kitchen walls and ceiling (was plastered 3 weeks ago) and was wondering if misting it with Dulux Matt would be OK to prep the plaster.
Thanks,
Mitch
Matt to mist
http://www.dulux.co.uk/products/matt
Acrylic Eggshell for walls and ceiling
http://www.leyland-paints.co.uk/leylandtrade_productdetails.asp?prodid=4
The Dulux matt is suitable for diluting to mist coat with but it is an expensive product to use for that purpose. The standard paint for misting is a white contract matt, diluted with around 20% water. It's much cheaper and is breathable to allow any moisture still in the plaster to continue drying out. Once you are satisfied that it's dry, you can then use the acrylic eggshell as the finish coat(s).
Great. It is what I have left over from my front room. It's just i was advised at SDM against using Dulux matt due to it having vinyl in it (I think he may of been confused with Vinyl Matt).
I wasn't sure if this did, but the above is the exact matt I have already.
Even vinyl matt can be used to mist coat with, provided it is thinned and the plaster is dry, but it is usually avoided because the vinyl will seal any remaining moisture from the plaster beneath the paint film which could lead to issues later on. Basically, you need to ensure the plaster is fully dried out before applying any kind of paint containing vinyl.
