- Joined
- 27 Jan 2008
- Messages
- 27,661
- Reaction score
- 3,347
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a Hotpoint Fridge/Freezer which was condemned as the insulation had failed. There was also a problem when one opened the door the light started to flash but it still did work, clearly a problem but what I wanted was to move beer brewing into the garage which in the main does not need the fridge all it needs is a heater and thermostat which I have set up using a demo under floor heating tile 18W and an electronic temperature controller.
However summer months are the dry season and from earth June to mid September brewing stops. I have been considering next year trying to brew through the summer and so have been monitoring the first brew of the season.
It would seem 60W refrigeration is too much, to cool down 40 pints takes time and if I simply connect both fridge and heater then the fridge will cool down to 5°C or what ever fridge is set at well before the brew cools down to 19.5°C I am aiming for. To sense air temperature will not work as air temperature and brew temperature start the same but then the brew produces heat so will become 3 to 4°C hotter than the air. But as time goes on it will return to same temperature.
It would seem three methods to get around the problem. 1) Change the settings on the controller as the brew progresses, not really a good idea as not really sure what stage it is at. 2) Limit how cool the fridge air will go, at moment around 5°C raising this to say 17°C would reduce over shoot. 3) Limit time the fridge runs for.
Likely the latter is the easiest just fit a time clock with 1 out and 9 in as it goes around the 24 hours so maximum run time is 15 minutes. However need to buy new controller anyway as one I have will either heat or cool but not both together, so using old one to limit how cold will likely be cheapest option.
However what ever of the two methods I use the fridge/freezer will be switched off and on with a regular self test and I wonder how long it would run anyway if being switched on and off all the time. Plus no idea what temperature freezer will reach.
At the moment in an emergency I can take out the fermentor and press it back into service, don’t really want to loose this option so not really willing to destroy it just for an experiment.
So will switching on and off all the time destroy my Hoover HCA 394 FK PW fridge/freezer or is it likely it will not damage any more than normal use? And of course if there is a way to alter the temperature without using external temperature controllers then great.
