Mobile Home 30 plus years old with old type screw in fuses. I do not want to swap it out but I would like to install the newer screw down fuses with resets. They only come fat and the previous owner put in the small adaption which now means only the skinny ones ( Fuses ) will go in. Fuses come skinny or fatter.
Question: This adaption appears to be pin locked as it is set in. Can I successfully get the adaption out without harming anything and then how. If it is pin locked ?????
_____________________________________
Moderator
Moved as originally posted in WRONG FORUM (UK electrics )
Moderator
