Galaxy G2 internal sounder
13 Jun 2013
Bedfordshire
Can anyone please tell me how to connect an internal sounder to the system? I have tried the speaker output on the panel with no joy and have also tried using the trigger output on the panel by programming the outputs with no joy, any help will be greatly appreciated.
Many thanks for your reply, is this true of all outputs, i.e. they only supply the negative to whatever is connected to that output?
In general outputs can be inverted in the attributes section of the outputs on many panels and can be done on G2 according to manual.
The speaker output is marked up as speaker neg so cant be changed as far as i am aware this is pretty much standard on all panels I have come across.
The external sounder can usually be changed to a pos trigger switching from SAB to SCB mode, the mode of the external bell boxwould also have to be changed or it be permanently on.
Hope this clarifies some of your queries.
