HI,
I had to move a PIR due to building work. The cable was not long enough so I had to extend it. I soldered the 4 cables and plugged it all in.
Everything was fine except I didn't take it out of engineer mode. I've since done a walk test and it detects movement and is fine. However when I exit engineer mode it says TAMPER FAULT.
I can't figure out what I've done wrong. Is there a way to by pass tamper so it works as normal?
I'm not an alarm guru
