gaps between spindals on banaster
16 Dec 2010
Birmingham
i rent out a property and the tenant as asked if they can remove the banister to open up the hall. i said this is not allowed due to safety reasons and they went on the internet and came at me with the gaps between the spindles are to wide, approx 210mm. i am under the impesion that new builds have set maximum gaps but this does not apply to a 1950s property.
please could someone shed some light on this.
It would fail an HHSRS inspection, and a claim for injury relating to the balustrades may succeed in common law negligence.
Both of these would override any past b/regs standards, in a letting context.
Max. distance between balustrades is 100mm. get a chippy in to fit new balustrades.
Don't forget any work done on your property will come off the end of year tax.
Andy
By spending money and improving the property can only be a benefit. When the tenant moves out and new tenants are found the work might have to be done in a rush as they have small children, you would not want to loose time when the property is empty. It is always best to complete work when the property is occupied.
Andy
The op's tenants do not want the balustrades, so won't what any new ones either, I suspect
How come they wanted to remove the bannister (if that's what you mean) and now they are complaining about the gaps?
You can't have the spindles without a bannister rail.
They are using the "unsafe" balustrades as a reason to have the lot removed
as an aside
100mm is maximum
its better to aim for 95mm max as wood moves
the 100 is a sphere off 100mm [child's head size]must not pass through any gap this includes any turning along its length
Thank you all for the replies.
I did try elsewhere to get this infomation. I suppose i was ignorant with the bannister but i will say i will add extra spindles to tenant. To be honest they are playing there faces to remove it all together. What makes it worse this is my mate who was made homeless and i brought the house to help him out.
What are mates for. even though he is a mate i am trying to do it properly and i have gutted the house to make it nice for them. he is a great tenant and i would let him remove the bannister but am not due to health and safety
thanks again
