Spent a few hours doing my research on this, so would just like confirmation this is okay.
House side:
Garage electrics to be spurred off kitchen ring with 2.5mm SWA (already laid now, 4mm was not available unfortunately).
Kitchen ring is protected by RCBO.
Spur is taken from 13a switched FCU in kitchen.
Garage side:
Garage consumer unit, 40A RCD 1 x 6A 1 x 16A MCB's
http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=31107&id=33248
1mm cable for lights and 2.5mm for sockets. I guess a radial circuit in the garage is sufficient, or is a ring better for any reason?
Question: Is it okay to have a garage CU with a 40A RCD when the ring already is on an RCBO?
Since the cable (9m run) is only 2.5mm, even though its protected by a 13a FCU is there any point in having a garage CU? If I'm mowing the lawn and run over the electric cable is it going to make any difference? Also, if the pond light trips would the garage RCD trip and NOT the RCBO, hence saving the contents of my freezer? Is this how it works?
Thanks,
Simon.
House side:
Garage side:
Thanks,
Simon.
