Hi All,
I'm currently rewiring the garage and the attached brick shed. Am using a wylex garage CU (RCD + 6A + 16A MCB - B's), and using plastic 20mm conduit and singles.
Question is if lighting *must* be loop-in? It'd be far easier, and use less copper, if i could run the garage lights and the shed light as "radials" from the same 6A MCB. This would result in two wires attached to the one MCB. Is that allowed? or should I really loop off the one light along to the next?
Second question - the CU is supplied by a 4m run of 2.5mm^2 3c SWA. To connect the armour banjo at the CU end to the CU's earth bar, what cable size should I use? will 2.5mm be ok? or should it be thicker? it'll only be about 20cm long.
thanks
slip
thanks
slip
