Garage roof replacement
16 Sep 2006
Fife
Hi
My flat (well, slightly pitched) single car garage roof is spent. It's those corrugated cement/asbestos boards, probably been up since the place was built in the 80s. A couple of years back I treated the lower half (section nearest the gutter) with sealant paint stuff and it helped a bit but truth be told the whole lot needs replaced.
I'm not totally settled in this property so I'm not inclined to buy the most expensive / tier 1 solutions for anything I need to do property maintenance wise. However neither am I inclined to buy cheapest.
The current garage roof is basically a few rafters with the corrugated sheeting attached and a gutter at the end. So, if I want to opt for a middle of the road replacement solution cost wise, what should I be looking at? Note I won't be diy'ing this.
What about something like this, basically a modern replacement for what's currently installed?
Onduline - Black Corrugated Bitumen Roof Sheet (2000 x 950mm) (roofingmegastore.co.uk)
If as you say your not sold on the house and looking to move in the not to distant future, then that's the route I would be going down.
Is it a prefab garage?
I wouldn't say I'm looking to move soon, however neither am I settled here, within the next few years I'd say. So I'm not interested in paying for an all singing/dancing replacement roof that comes with a price tag to match.
If by prefab you mean concrete sections then yes, it's a prefab.
Yeah concrete sections.
The only other form of cheap roofing is felt, but it's a lot of work on one of them prefab garages as you will have to add joists etc.
So your option of the bitumen corrugated roofing sheets is the best price/performance ratio.
