garage t handle replacement
1 Oct 2011
London
Hello
Is it possible to remove the t handle on a garage door and replace it with a new one?
No problem as a rule, obviously it helps if you know the make. Henderson is a common up and over door, for example.
John :)
The handle on the inside says westland but also say Yeovil.
Westland is a model made by Garador......you should get a handle easily enough from ebay or the manufacturer itself.
John :)
