Currently in the process renovating the garden.
I have a couple of areas where i am going to put in LED ground lighting which will be set in concrete driveways and a patio area.
For this i have run 2 3cx1.5mm sq. armoured cables which will go to a waterproof junction box.
Here these will house the LED drivers and anything else, photocells, maybea timer etc.
From these junction boxes can i just come straight out of these with rubber flex cables (due to LEDs just being low voltage) and run tracks underneath to the light fittings, the cabling will be covered with concrete so i am presuming that i do not need armoured cabling to the actual fittings.
any one else done something similar?
