Garden lighting question - connector boxes + cable recommendations
Discussion in 'Electrics UK' started by MiltonPFC, 19 May 2020.
  1. MiltonPFC
    MiltonPFC
    19 Dec 2008
    18
    Thanks Received:
    Hampshire
    Country:
    I have 6 x IP66 rated garden lights (mains powered) to install in a garden, and plan to run these off a spur (with a FCU fitted) from the downstairs ring main.
    It is a small square garden, and the lights will be positioned in flower beds by the left and right hand garden walls (ie. 3 lights per side). Was planning to run had mains cable along the garden walls and to attach to each light via waterproof connector boxes. Each light comes with approx 1M cable already attached).
    Looking to keep costs realistic.
    I have a couple of questions regarding suitable cable and outdoor connector boxes that I would appreciate your help / recommendations on :
    Cables :
    In one online video I saw armalite heavy duty cable was used, another one had HiTuff cable housed in a flexible conduit.
    Given there’s only 6 lights what do you recommend ? I don’t wish to bury the cabling, just have it sat on the surface in the flower beds amongst the plants.
    Waterproof Junction Boxes and Glands :
    Based on the cable choice above, what waterproof junction boxes and associated glands do you recommend?
    I have seen Wiska boxes online - presume it’s just a case of right gland size for the mains cable diameter ?
    Also, is it ok to use using standard connector blocks inside the Junction boxes to connect the cables? Any additional treatment needed ie. once connected cover in resin to waterproof?
    Genuinely appreciate your help - Many thanks in advance
  2. Sponsored Links
  3. winston1
    winston1
    11 Jan 2010
    7,343
    Thanks Received:
    572
    London
    Country:
    I would not want 240v cables in my flower beds unless it was SWA or in steel conduit. I would use 12v or 24v lights myself.
  4. chivers67
    chivers67
    18 Nov 2008
    1,478
    Thanks Received:
    188
    Surrey
    Country:
    To have cables sat on top of flower beds is an accident waiting to happen, even Armoured cable should be buried to prevent accidental damage. You'd be best off bringing each cable down the wall burying it deep and bringing it up at the light point but it needs to be protected.
    I prefer Winston's Extra low voltage option but it sounds like you already have the lights.
  5. MiltonPFC
    MiltonPFC
    19 Dec 2008
    18
    Thanks Received:
    Hampshire
    Country:
    Yes have already purchased the lights - needed mains powered as I required higher wattage / more powerful lights to light up trees, etc
    This is one of the videos I watched ref installation .... hence my suggestions above ... and if you agree etc ?
    cheers
  6. SFK
    SFK
    23 Jul 2010
    2,033
    Thanks Received:
    476
    Oxfordshire
    Country:
  7. JohnW2
    JohnW2
    28 Jan 2011
    49,247
    Thanks Received:
    3,253
    Buckinghamshire
    Country:
    Car headlights, not to mention 20-50W LED 'worklights' etc. don't need 'mains' to produce a lot of light!
    Kind Regards, John
  8. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,786
    Thanks Received:
    1,009
    Durham
    Country:
    Temporary installations allow for TRS cable laid on the surface with Dri boxes for connections to the final appliances.
    Your setup is not going to be temporary so draping long lengths of mains cable in the flower beds is not going to be adequate.
    IF your garden is small enough that the 1 metre cable from each lamp reaches the fence then you could fix SWA to the fence as a radial circuit with multiple (outdoor) sockets or suitably rated adaptable boxes. You could use conduit and singles for a similar scheme.
    Or you could be sensible, bin off the mains lights and use some ELV LED stuff instead- with the bonus (if it floats your boat) of colour-changing trees as well as the inherent reduced risk of injury from ELV systems.
    Whatever you decide to do (including ELV), the outdoor stuff must be fed via an RCD. If the RFC you are spurring from is already fed by an RCD then fine , if not then you'll need one.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
