We have combicompact vcw gb 221h vaillant gas boiler pump type: vp5-ze 15, which has gone faulty. The picture of main parts can be seen here: http://2move.me.uk/boiler.jpg . It has suffered from the same fault for years but has not been difficult to remedy within a few hours or a day or two. But this time the fault refused to go away like before. The fault is this: When the fault starts, the boiler doesn’t push hot water into central heating and bath hot water tank. The water at sink tap becomes extremely hot, almost to the boiling point. The boiler externally becomes hot a lot more than usual.
Before whenever the fault started, I put the main electricity and pilot light off and opened hot water tap at the sink to let all hot water comes out. After that I left it for a few hours until it became cold completely. When it became cold enough I put main electricity switch and pilot light on. Most of the time it restarted working all right on the first attempt. Some times I had to repeat the operation a few times until it worked. This some times took a day or more. But when it worked, it continued working for a few months before the fault came back.
Recently the fault started to come back early almost within a week. Finally the fault refused to go away any more since over a week ago. I gave up and decided to call a plumber to check it. We suspected some thing was wrong with pump but the pump was working. Everything else was in order. Finally we decided the cause must have some thing to do with the pump. So we decided to change the pump. The plumber closed central heating and hot bath water switch off but left sink hot water tab switch on. Today I was planning to go out to shop for the pump. But before I went out for curiosity reasons I put central heating and hot bath water tank switch on. It immediately started working. Now I changed my mind to buy a pump before I find out more.
Now please is this fault has some thing to do with the pump or something else? Please help. It will come back soon and it is very cold.
