- Joined
- 25 Nov 2013
- Messages
- 42
- Reaction score
- 0
- Country
Hi Folks,
I need some advice, Here is an overview of my heating system
Ex Council House with 3 Bedrooms
7 Double Radiators + TRV's
5 Single Radiators + TRV's
3 Taps that can supply hot water (Shower / Wash Basin & Kitchen Sink)
Open Vented System with Header Tank / Expansion and Indirect heating Cylinder.
The pipes are 15mm to Radiators with the main flow and return being slightly larger possibly 22mm the entire system is copper pipe.
The advice I need is
I am having Installers coming out this next week to quote for Gas.
What type of boiler do you suggest I need? E.g. If they quote for a boiler that is too big for my needs?
What boiler types should I steer clear from, I hear mixed reviews on Baxi and Glowworm?
Does my pipe work need upgraded?
Does my radiators require upgrading?
My hot water tank is in a cupboard on the second floor with all walls being plasterboard. Can I install a combi in this cupboard?
Can I have the flue run through the void in the attic and out through the roof?
With regards to the condensate can I choose to have a pump fitted to allow the pipe work to run horizontally through the attic before running vertical.
If someone can advise me that would be great, I will put the quotes up but perhaps if there are any questions I should be asking or whatever?
I am new to getting people giving me quotes so not quite sure what I should be asking / showing?
Cheers,
Dean
Cheers,
Dean
