Gas meter cupboard change ?
18 Aug 2025
Hi guys ive had BG round to remove my gas meter as im doing work on this house for myself and thd old external meter cupboard is was cracked and broken
My plan was just to pry it off the wall and then in the future i could just slide a new box over the valve , however when i came to take the final bit off it seemed fixed in around the valve coupler
Ive spoke to the local gas network and they have said i must not remove the final bit of broken box as i could cause a gas leak
obv im not gonna loosen any nuts or the valve which they maybe though i was going to but by breaking off the rest of this white plastic do anyone really think it will cause any leak....
you wont cause a leak just break the bits off as none of the box forms any sort of seal with the gas service .
The black ring is possibly just like a big circlip holding pipe to box
Then you need a mark2 surface box when replacing it
Maybe they imagine that the plastic is supporting the pipe, which will be vulnerable to being yanked if unrestrained.
Thanks for the replies
i managed to get it off without causing any issues i just didnt know if it was some sortof seal , i presumed they would just say no dont remove it cause they wouldnt know if i was gonna yank and pull at it or try and take the valve off but there charges are a joke
they wanted 135 quid just to replace the box cover and that was just the cover they have said if the back plate needs changed then that will be classed as a alteration and will be a different charge so god knows what that would cost...so im hoping when i get the new back plate i can just slide the whole bit back in
