Gas oven "cooling" fan not working.
2 Feb 2020
Hi I have a Belling Classic 60G model 444443750 Gas oven/hob.
It is a freestanding cooker which is double oven, the top oven being a gas oven and electric grill and the lower one a standard gas oven.
Recently the cooling fan doesn't seem to be kicking in on the lower main oven and I seem to be getting a bit of condensation dripping from the door as it warms up.
The fan kicks in and works fine with the top oven and with the grill.
Any ideas?
Many thanks
Dave
Have you got a multi meter ?
You're gonna have to test you have voltage at the fan when the oven is on
Does the fan turn freely when you spin it by hand?
Thanks for your reply.
The fan turns fine by hand and works fine on the top oven. I'm assuming that there's only one fan but could there be another one tucked away that isn't immediately viable form the rear without taking the rear panel off?
Dave
That will teach me for assuming there will be two fans!
I can't find any information on how your fan is wired
So you will have to fault find , you will have to trace the wiring and test it with a multi meter to find the problem.
If you look at the working circuit first then compare it the non working circuit you might get lucky and find an obvious problem
Thanks, will do.
Is it controlled by the oven thermostat or is there usually a separate one for the fan?
Cheers
Dave
I would assume the oven thermostat, I'm just guessing but it seems logical
Wish I could help you more but without a wiring diagram I'm stuffed
Someone else might have worked on your oven or failing that throw an email to belling and ask them
