Fan assisted oven not switching on
tej
12 Dec 2005
Hi
I have a fan assisted oven cooker and it has stopped working. No light comes on when turning the knob and the oven does not kick in. The grill works fine.
Any ideas guys?
No its the grill and the clock work fine which are being powered
The clock maybe working, but have you switched it to timed in error.
There could be a thermal cut out.#
Is it dbl or single oven, what make?
Assuming as DIYISFUN said, you have it set to manual rather than automatic, then the most likely problem is the either a thermostat or the temp regulator has failed. Do you have a meter or means of testing?
Hi Cooker is bella but dont have a test meter. Have to get a few quotes just dont want to get conned!!
