gas pipe insulation
25 Nov 2005
trying to replaced the kitchen wooden floor with concrete. the 22mm gas pipe is going across the floor. can it be insulated with normal pipe insulation before applying the concrete. or does it have to be with special ducting, if so how can the ducting be inserted without disconnecting the pipe?
Denso tape. Minimum depth I can't remember though. (It's in the book)
40 or 50 mm coverage.
the pipe might be disconnected after all to be re routed. is there any plastic pipe ducting can be used other than Denso tape.
