Two companies including British gas and a large local said they will fit new 22mm from metre to boiler. it's hidden in loft, yet it was 22mm to just above the boiler (they didn't check). then reduced to 15mm.
3rd guy cheapest quote says 28mm from metre. I looked at the rough guide it's 12m so said okay fine. he's fitted 28mm to just outside metre then reduced to 22mm.
looking in the metre cabinet the regulator has a 22mm flexi pipe on it. the pipe out of the ground is god knows huge! so my question is does 12m of 28mm give enough head room for the boiler/4 hob gas oven? does the 22mm inside the gas metre ruin everything?
it's his 4th day tomorrow so last chance I think to ask.
