well 99.9 % certain the gas supplier has to do this for you you need to tell
them how many appliances you intend to use and if you are planning any big changes which would alter amount of gas used building heated swimming pool building houses in your garden all these would effect the size of the supply even just the length of this pipe would mean bigger pipework to give you the right pressure to run your appliances safely and effectively
would have though 350metres at least £7000/£10.000 grand if you get a nice surveyor i had main moved 2metres on an extension £2200 so be prepared or rethink whats wrong with oil /lpg
peekay53
