I am trying to get some clarity on a situation
I had a boiler replaced some 5 to 10 years ago
It was situated where the old one had been close to floor level on an exterior wall beneath a window
The boiler is a combi condensing boiler by Bosch Worcester
The flue exhausts straight through the wall , at the time the engineer informed me that the window needed to be fixed closed to be safe as far as carbon monoxide emissions
I never fixed the window closed
I now have moved to australia and the sister in law is no longer living in the old home and we are considering renting the property
I was hoping to just add a flue extension and raise the external vent to above the window
The advice I have received has been mixed and mostly has suggested I need to reposition or replace the whole system
Can anyone advise on the availability of flue extensions, bosch technical suport suggest there are parts service engineers suggest not?
The legality of just extending the flue above the window and what clearances may be required
If a flue extension can not be sourced or is not suitable, would altering the window to a fixed solid glass pane that can not be opened be a suitable alternative to any carbon monoxide issues
Since reading around this area, trying to educate myself, I have come across some suggestions of flues needing to have a guard attached if not over 2.2 meters high , I am unsure if my vent has a guard , is anyone able to comment on the addition of these
If a flue extension or guard are added does this constitute work that may require the boiler to be compliant with current regulations rather than those that were current when it was installed
And finally the boiler has a condensing chamber and releases 100 ml volumes, this discharges onto a flat roof terrace that has drains and gullies on. One engineer suggested this was illegal and that a condensate pump needed to be installed to pump the condensate to an internal waste, the intallation instructions make me think that this service person was just not aware of this type of unit as it showed 4 options for dealing with the waste 3 of which were externally discharged
Thank you so much for any help you can give
I am really struggling with getting a letting agent to answer these questions
Andrew
Andrew
