I have a house with a sideway between the two houses which provides access to two other houses. I want to put a wooden gate across the gap between one garage (brick built) and another garage which is prefabricate concrete. I want to avoid attaching anything to the prefabricated concrete garage in case it cracks it and have heard as these often have reinforcing in them it isn't easy to fix to them. The ground is concreted but not good enough to take raw bolts e.t.c
The sideway will be used by builders, tree surgeons e.t.c. I thought of using:
1. Wooden posts - wanted to avoid these as they will eventually rot and want to avoid having to re-concrete them in.
2. Concrete gate posts, was thinking if these get knocked they may crack and so wanted to avoid this. I also thought of using concrete spurs and attaching wood posts to these,
3. Steel posts I want the gates to be 6'6" high and was thinking I need 10" posts to allow for concreting them into the ground. I have had trouble finding these online though. Is this something people just have made to order?
I am also not sure how I can easily attach the wooden gate to the steel posts? I was thinking they need drilling and bolts to attach the hinges to the post.
If anyone has suggestions or advice it would be appreciated.
Martin
Martin
