Gate valves on central heating
17 Mar 2005
hi
Is it ok to use gate valves on the flow and return that feed my kitchen rads
I'm in the process of fitting a new kitchen and I need to cap the pipes off but I will not fit the new rad for some time due to other works I am planning and by this time the kitchen will be finished so I don't want to just have then capped and do a quick live connection later in my new kitchen so was planning to fit two of the red wheel gate valves to the pipes so I can continue the pipe work at my leisure.
They will be in a good position to be boxed in after.
Thanks in advance
Ps. It's a combination boiler if that makes a difference ?.
Yes, but full bore lever valves are better an no more expensive than DECENT gate valves.
Do not use the slotted screwdriver ones. They're shyte.
