Hi all
I recently noticed some draft coming through our 15 year-old UPVC DG window openers. The hanging seems straight so I'm thinking the seal or gasket between the frame and the opener needs replacing. It's getting sticky and losing its spring, but not brittle.
Looking on-line I can see it is a R4055X and commonly available, so I bought a 99p sample pack to confirm. I was disappointed to find that the sample appeared to be a thinner and floppier rubber that didn't sit quite so snugly in the groove and is visibly inferior.
Are there any reputable suppliers you can recommend for this flipper gasket. Don't want to buy 20 metres of the stuff to find it is worse than the original.
MM
MM
