Glazing tape vs silicone - acoustic performance
7 Feb 2010
When fitting double glazed units into timber frames, is there any difference in acoustic performance between fitting them with glazing tape, or with silicone (neutral cure, obviously)?
Richard
Richard, good evening,
Firstly I do not have a definitive scientific answer, but?
What I thought was that if we consider the glass to resemble a Drum Skin?
If that "Skin" is fitted hard to the frame, by the reasonably Inflexible "Tape" then I think this fix method will transmit more external road noise [for example] as opposed to a flexible medium that will hold the glass just away from the frame and also provide a resilient "Buffer" between our Skin and the hard frame?
As previously noted the above is not a Scientific Specific answer, but may be worth consideration.
Lets see what the board makes of this question?
Ken
could also be said that the flex in the silicone might cause the drum skin to vibrate more.
Personally I doubt it makes a 5h1t of difference
That was my suspicion, and the sort of answer I was hoping for ;-)
The joiner who made the windows for me has rebated them and made the beads on the assumption that I would be using silicone, so there's no space for tape without leaving the beads proud of the surface of the windows. And traffic noise is an issue.
Don't glaze with clear silicone, use a clear polymer instead like fix all crystal clear.
