im working on a gw 24ci.
the problem was the there port vavle leaked water into motor and blew it up, so i changed cartlige which stoped leak, and changed the motor.
still not working, the pin in the motor is not coming in or out, it says in the manual that the voltage for the motor should be between220 and 240 volts ac, im getting 212vac on the correct pins when dhw/ch demand is on.
would the lack of 8 to 28 volts be the cause of the motor not running in which case i m quessing change the pcb aswell.
any body any ideas
any body any ideas
