Glow Worm 30ci
12 Apr 2010
Kent
Hey,
Moved house in summer, no heating on.
Put the heating on the other day and this boiler is firing up OK, but then after a few minutes fires down. Then up, then down.
Every few minutes between up/down.
You are not telling us much!
Are an owner or tenant?
Do the rads get hot?
Some room thermostats allow cycling to be set (eg; every 6 to 20 minutes).
What stat is fitted?
Sorry chaps.
Owner. Rads get hot yes. Hot water is fine, will run for ever (I thought it might be overheating).
No stat fitted (yet) - just using the mechanical 'pin' timer built-in.
It sounds as if the gas settings may need adjustment but not a DIY job.
A proper service might be all that's needed!
