Hi, I switched my boiler off to fit a new shower thermostat but when I tried to switch it back on it's completely dead. There is power to the boiler but is there anything else obvious I can check? I have also checked the PCB fuse (the fuse is working but there is no power across the fuse) and the switch.
I did read in the manual of a Safety Shutdown, what is that? The manual just says if this happens call Glow Worm. I can't think of anything that I might have done to trigger a safety shutdown.
Thanks as usual.
Pete
Thanks as usual.
Pete
