Hi I had a boiler fitted recently and the hot water is now not working. The boiler fires up for the central heating and is really hot, however when you put on the hot tap the boiler fails to ignite and doesnt supply any hot water. Any suggestions please please help.
Then suspect the domestic hot water flow sensor has stuck or failed in some way.
There probably is a filter in the cold supply which may be restricted.
These boilers require approx 3 litres a min to operate, check you have that.
