Hi all,
I recently bought Glow-Worm Ultracom 2 30 CXI as well as Climapro2 control room thermostat. The reason for my post is that I am not entirely sure the way it supposed to work when it comes to central heating.
Currently the temperature is set to 19 C between 8am and 10pm every day. So the boiler comes on in the morning gets the house (2 bed mid terrace) to the temperature set point and instead of switching itself off ??? stays on ALL day till 10pm when it’s programmed to 15C for the night.
From what I have noticed the pump is on all the time(between 8am-10pm) and the burner fires up from time to time. My confusion comes from the fact that my last boiler and its basic thermostat simply switched itself off(including the pump) after reaching the set temperature.
Is that the way Climapro2 control is supposed to control the central heating? Get the desired temperature and maintain it being ON all the time?
I do understand that when it’s maintaining the temperature it modulates the burner to keep returning temperature low so it stays in condensing mode most of the time. But the burner isn't on all the time it comes on maybe every 10-15min depending on the outside temperature so it’s not calling for heat all the time it’s just maintaining it but the look of it .
Wouldn't that cause excessive wear and tear especially to the pump if it works continuously for 14 hours a day?
The interesting thing is that it switches itself off when it gets 0.5C higher than the set point. The problem is that since it starts modulating when it gets close to the set point it never overshoots therefore it's always on(the pomp at least).
Any thoughts would be really appreciated. Thanks
