glow-worm combi - hot water turns cold at random
3 Jan 2010
even with the heating off,the boiler can take 10 minutes to produce warm tap water,then without doing anything it will then turn cold again.
can anyone identify a possible cause and solution?
thanks in advance.
Ad.
Glow worm and Combi. Thats a lot of different boilers. Can I have a model? (Well, obviously not the leggy blond type :( )
What Combi's are available in your location?
Huw.
i will fix it for free if you send the air fare!! (just saw your location! - hope you get it sorted straight away :D )
thanks Huw.i can provide one of your requests-its a compact 100E.
also to get warm water ,the tap needs to be on a very low flow rate.
Approx 7 years old.weve had problem over 1 year.
Ad.
thanks. How does this account for the temperature rising and dropping despite you doing nothing to affect the flow thro the boiler ?
Ad.
Water section. Just a diaphragm needed. Unusual star shaped screws to get to it. Pi ss easy to change though. Dont hang about, its bound to be leaking into the DHW switch. Compacts leak for fun.
Huw.
