I have a leak from the bottom left hand side of the plate heat exchanger.
I suspect the sealing gasket has failed. When the mains water supply is turned off the leak stops. Looking at the service manual the heat exchanger is secured by just two screws.
Is it a dificult job to remove the unit and replace the four gaskets.
And can the gaskets be purchased seperately, I havent had any luck finding them as a seperate item.
Help appreciated.
Help appreciated.
