The heat exchanger bottom plate is leaking in my Ideal Icos HE12 boiler. Apparently its not an O ring type gasket but a silicon paste and they often fail if they are stripped down and a new paste applied.
So what I want to know is can I put Fernox sealer into a microbore system or is it likely to block if theres an air bubble....and is it likely to do the job of sealing the heat exchanger?
Thanks for any input
