Glow-worm compact 100e
24 Jan 2019
hi help....... had a leaking low pressure water switch so replace the o ring all good. Came home today and water is running out of the pressure switch so bled the rad and water eventually stopped. Question is the switch seems wobbly now? Looked at the manual and think there Sb 2 clips ? I’ve only ever had one. If I order a new switch which comes with the o ring will it still wobble? .... cold in Brum thanks for any help
