hi, does any body out there know how i can release the pressure from my expansion vessel , last time i tried i just cracked the nut and got wet any hlp much appreciated thx
friend of a friend did some work a while ago didnt put inhibitor in now plate heat exchanger fouled, ran 2 lots of cleaner through no change , got new parts and inhibiter , need to remove flexi from tank to wiggle part out acess is a bit tight to say the least
