Glow Worm F13 error
31 Jul 2008
Northamptonshire
I'd be grateful for any help. I have a Glow Worm sxi 30 boiler. It is about 2 and a half years old.
Recently it has been coming up with an F13 error, which according to the user manual is a PCB fault.
When I switch the boiler off and switch on again, it works fine.
I intend to check the connections, and if all seems well then I understand I will need a new PCB.
Is there any reason I shouldn't take the cover off with the power supply to the boiler switched off to check the connections?
If the connections to the PCB are ok, is there any reason I shouldn't just go ahead and replace the PCB, and where would the best place be to get one?
Thanks for any help
