glow worm 30sxi fault
5 Jun 2012
Devon
Im a retired installer but am having trouble with my own boiler.glow-worm 30 sxi system boiler.Boiler comes on when clock calls,but when it turns itself off on the boiler stat it does not come back on (shows f1 or f2 fault ignition f.last week showed f13 fault pcb)once ive reset it it fires straight away.boiler burner and igniter changed because burner seal leaking. any ideas what fault could be,im getting baffled?
From your description there are a few things to check.
As your getting multiple fault codes and a seal failure check that the wiring harness hasn't been damaged by heat.
Sometimes the boiler will cut out on minimum rate and constantly keep going through the ignition sequence till it goes to fault code.
F2 is usually a fan fault so as mentioned before check the harness.
Finally it could just be a pcb fault
Measure thermistor values both at the thermistor and at the circuit board.
Does the boiler actually come on and try to fire then fault code?
Or just never come on again?
Did you ever get this sorted out? I am having the same problem, boiler fires up get the water to temperature and then the flame shuts off, will not re-ignite. My gas engineer is talking about having to replace the boiler?
