Hello
I seem to be having some trouble with my central heating system at the moment. As it's gotten colder, I noticed that the radiator in our upstairs loo was only getting warm at the bottom, while the other radiators seemed to be warm all over when the central heating was running.
After doing some reading online, it looked like the problem was that the radiators needed to be bled (first time we've ever done it in seven years of living in the house). The bathroom radiator contained quite a lot of air, and there was a bit of air in a couple of the other radiators upstairs.
The problem is that now none of the downstairs radiators will warm up at all. The ones upstairs are quite warm.
Our system is running on a Glow Worm Micron 40FF inherited from the previous owners of the home, who were DIYers, and as near as I can tell, there is a Grundfos pump taking the water straight out of the boiler and sending it upstairs before it goes anywhere else.
I suspect, based on what I've read here, that the system doesn't have sufficient pressure since the radiators were drained, and that we might have an air bubble in a pipe somewhere stopping the circuit of water downstairs. I'd like to try topping up the boiler before we call out a technician but I'm having a bit of trouble doing that.
My problem is that I can't seem to *find* the top-up valve or even the pressure gauge in our system - where would this be located on a Glow Worm 40FF, or what might it look like?
We have one narrow pipe going into the bottom of the boiler from the gas meter, which presumably is the boiler's gas supply.
We also have another wider pipe going into the bottom of the boiler, with a sort of T-joint on it outside the boiler casing. The T-joint has one pipe that goes upwards and looks like it goes right up into the ceiling in the room; on the opposite side of the T from the boiler, there's a short spur that ends in something that looks like it could have an allen key or a handle stuck into it but I have not tried doing so.
One wide pipe comes out of the top of the boiler and goes up to the pump.
Am I being totally thick and not seeing something I should be? Did the DIYing former owners of the house do something strange and make the pressure gauge vanish?
Is the pressure gauge located inside the boiler housing, and if so, is it somewhere user-serviceable?
Any help and advice - and especially photographs of what I should be looking for if possible - would be very much appreciated.
- Ssthisto
- Ssthisto
